Assistant2 v 1.0.6
2399 6 2016-10-25
gboivin
Flight distance : 1544416 ft
I installed the newest version of Assistant2 v 1.0.6 on my Mac. When connecting the M600 than clicking on the M600 button, A message pops up saying to upgrade they latest verion of firmware, the current version is not supported. My firmware is 1.0.0.43. Acording to  The Assistant2v 1.0.5 (older app) When running the 1.0.5 version everything shows current in all updates. The below is a screen shot when trying to use the newer Assistant2. Any ideas? When I click update nothing happens. Again the firmware is showing 1.0.0.43 for the M600.
2016-10-25
DJI-Jamie
Flight distance : 112405 ft
You should be able to hit the 'X' button and bypass the 'Update Now' option. When you lets you into the firmware section, you could refresh the page and it should clear the message.
2016-10-25
gboivin
DJI-Jamie Posted at 2016-10-26 06:45
You should be able to hit the 'X' button and bypass the 'Update Now' option. When you lets you into  ...
No good goes back to main menu with LB2 and M600 options. It still works with the older version v 1.0.5 Assistant2. M600 firmware v 1.0.0.43 dated 9/29/2016.
2016-10-25
gboivin
See previous Notes, Was having a problem with v1.0.6 Assistant to work with M600. Just saw a notation under M600 downloads that the newest version isn't working with M600 yet. Download the prior version.
Just a heads up to all our M600 people!
2016-10-26
iSkyUnmannedSys
Flight distance : 7152087 ft
gboivin@msn.com Posted at 2016-10-26 10:48
See previous Notes, Was having a problem with v1.0.6 Assistant to work with M600. Just saw a notatio ...
1.06 is currently for the stand alone A3 version 1.5. I'm guessing the M600 firmware update will be a long soon
2016-10-26
DJI-Jamie
gboivin@msn.com Posted at 2016-10-26 07:46
No good goes back to main menu with LB2 and M600 options. It still works with the older version v 1 ...
Since there hasn't been any new firmware for the M600 that is only available on v1.0.6, you're totally fine to stay with 1.0.5 for now. Like iSkyUnmannedSys mentioned, only the stand alone A3 has firmware that's only available on v1.0.6. Most likely there will be M600 firmware made available in the near future that will require the new Assistant 2.
2016-10-26
jbourne
Can DJI assistant 2 v1.0.6 still use DBUS?
2016-11-15
