HELP: Gimbal Disconnected, but (sort of) works??
Medevon
New Zealand
Hey everyone. I was going to take my P3 out for a flight today, but the gimbal decided cut out. This happened before a few days ago also when I was out for another fly, but I just restarted it and it worked perfectly. As you can see in the video, the gimbal works for a good 10 seconds until it drops, and it says it's disconnected in the app, and provides no image transmission. Also, it takes ages to turn it off. I've tried restarting it 3 times, but nothing's changed. Any advice? Cheers!
2016-11-2
Hi Medevon, when you turn on the aircraft, will the gimbal calibrate automatically?
Please try to replug the 6pin and 8pin cables on the gimbal and do the linking again.
2016-11-2
Phantom3ProPilo
Flight distance : 612825 ft
Croatia
The two cables may be disconnected
2016-11-2
Buzzyone
Flight distance : 4647913 ft
Potentially failed flex cable on gimbal.
2016-11-3
