Forward Vision System Icon Red
8933 18 2016-11-8
phatee
Flight distance : 36165 ft
Quick Question
I'm trying to figure out why the Forward Vision System icon is on the top tool bar of the app is red.  i can't figure out why.
2016-11-8
Is there any error message show up in the app?
Please try to do the VPS calibration via DJI Assistant.
2016-11-8
Visualkaos
Flight distance : 755988 ft
It usually means it is turned off.
2016-11-8
Visualkaos
Do you have it in sport mode?
2016-11-8
phatee
Visualkaos Posted at 2016-11-9 01:41
no i don't
2016-11-8
phatee
here's a screenshot
2016-11-8
phatee
please tell me i don't have to send this back...please dont....i tried to recalibrate 4 times with the same result.
2016-11-8
Hi, could you please enter the visual navigation settings to check if you had enabled both visual sensing system and vision positioning?
Here is the screenshot for your reference.
2016-11-9
nils_heidorn
Flight distance : 183537 ft
Hi !
One guy had this and he left one of the transparent stickers on the VPS.
Hopefully thats just it, good luck !
Nils
2016-11-9
phatee
DJI Mindy Posted at 2016-11-9 03:58
Hi, could you please enter the visual navigation settings to check if you had enabled both visual  ...
they are both on.
2016-11-9
themosttoys
Not enough light for the sensors (most likely the ones on the bottom) to work.  Take off and hover, if there's enough light, the VPS will kick in, it will go into OPTI mode and that symbol will turn white.
2016-11-9
phatee
themosttoys Posted at 2016-11-9 09:53
Not enough light for the sensors (most likely the ones on the bottom) to work.  Take off and hover,  ...
got it...my room isn't that bright.  i'll check it out side to see if tit chngess.
2016-11-9
phatee Posted at 2016-11-9 22:59
Please keep us posted.
2016-11-9
riyadc
Flight distance : 21585 ft
I just got mine a few hours ago and have to same issue, but it's night and dark outside, hopefully it'll work tommorrow morning
2016-11-16
AusAir
Flight distance : 425049 ft
Needs 100lux to function.
2016-11-16
riyadc
riyadc Posted at 2016-11-16 21:22
I just got mine a few hours ago and have to same issue, but it's night and dark outside, hopefully i ...
Flew it this morning during the day and Forward Vision System was working properly!
2016-11-17
Nick Gregory
Flight distance : 174 ft
This place is just amazing. Having had mine back from repair, I had the same issue too. I did a quick search which lead me to this thread, and "boom" Problem solved.
Too dark and sensors weren't getting enough light.
2017-12-16
Nick Gregory Posted at 2017-12-16 22:49
That is great to know the community helps, this is why it exists.
Please let us know if there are other problems.
2017-12-17
aigarart
Have the same issue 1. Calibration done 2. All is on 3.  transparent stickers on the VPS - removed 4. There is enough light as well in the room or ouside. Tried already
2018-3-7
