Follow Me Mode
1578 12 2016-11-15
Calvin1008
No matter how many satellites i have showing on my display, my follow me mode always says " gps signal too weak" ! How do I fix this problem??
2016-11-15
fans2d27c02a
I'm curious about this as well. Tried using my phone and an Ipad with no luck.
2016-11-15
Farnk666
Flight distance : 1711394 ft
This has been covered before many times - the controller's GPS (different to the aircraft's GPS) is obstructed by the tablet and doesn't get a solid position lock.
DJI's response is to use a tablet / phone which has a GPS function, which the GO app will use instead.
It doesn't always work however - even with solid GPS signal.
2016-11-15
Hi Calvin, could you please clarify what mobile device you are using?
Just as Farnk666 mentioned, please make sure you are using a device which has GPS module.
2016-11-16
Donnie
Flight distance : 3636782 ft
From what I always understood was the Go APP device had to have GPS/ cellular capability .  I have an I pad  pro with GPS and it works just fine , I dont have the Cell option activated .
Can you try another device with GPS capability ?  Like Most cell phones have this , as long as it is compatible with the Go app.  try this for testing purposes.
What device  are you using for the Go app ?
Please someone correct me if I have this wrong.
donnie
2016-11-16
delcodrones
Flight distance : 440367 ft
I'm getting the same message when I took her out last weekend Follow me mode disabled as a result will not work. Using an ipad mini it was also the first time i tried this mode.
2016-11-19
DJI-Jamie
Flight distance : 112405 ft
delcodrones Posted at 2016-11-20 08:05
I'm getting the same message when I took her out last weekend Follow me mode disabled as a result wi ...
Does your iPad mini have cellular data, or just WiFi?
2016-11-19
delcodrones
DJI-Jamie Posted at 2016-11-20 09:21
It has wifi but I use my phone as a hotspot and the ipad mini connects to the internet through the phone
2016-11-27
Farnk666
But doesn't share the GPS data. You need a device that has GPS inbuilt
2016-11-27
delcodrones
Farnk666 Posted at 2016-11-28 12:38
So the device used to connect to inspire must have its own data connection or cellular connection for follow me to work? The iPad has a GPS built in
2016-11-27
Farnk666
delcodrones Posted at 2016-11-28 12:46
So the device used to connect to inspire must have its own data connection or cellular connection f ...
No, the device needs to have a GPS inbuilt.
Data connection is irrelevant.
The WiFi version of the Ipad doesn't have a GPS, the cellular version does.
Therefore - your iPad will not work for 'follow me'.
2016-11-27
delcodrones
Farnk666 Posted at 2016-11-28 14:04
Okay I got it. Thanks
2016-11-28
DJI-Jamie
Farnk666 hit the nail on the head. If you use your phone or a cellular data tablet, then Follow Me mode would work.
2016-11-28
