battery firmware update
1688 5 2016-11-22
Defender4he1
Flight distance : 466 ft
Hi  replaced my drowned P3s with a P3 adv.I have 3 batterys 2 that came with the advanced and 1 from the standard (not the wet one)
The drone flies perfectly on all batterys but one has a notice an update is needed If I disregard this .Any likely problems ? it is nearly new
Thanks  Noel
2016-11-22
DJI Natalia
Flight distance : 318 ft
Please upgrade the battery so that the firmware will be consistent with each other.
2016-11-22
PoppaHotel
Flight distance : 39600 ft
DJI Natalia Posted at 2016-11-22 05:48
HOW do we upgrade the battery alone?
2016-12-12
DJI Natalia
PoppaHotel Posted at 2016-12-13 13:26
After you finish upgrading the aircraft, then please turn it off, take out the battery which has been upgraded then put a new one into it, if you get a message it needs to be upgraded, please upgrade it.
2016-12-13
PoppaHotel
DJI Natalia Posted at 2016-12-13 23:53
Does this include the entire process of upgrading the aircraft again along with the battery?  With this being explained, all of my problems may have been eroded away with the latest firmware update.  The original "Motor Obstructed" message no longer populates after the firmware update.  The battery update process is still ominous and unclear.  I do have at least one battery that is giving error "Battery Broken - return for repair" along with "battery - firmware upgrade needed.
Any input or consideration is appreciated.  I WANT TO FLY THIS WEEKEND!
2016-12-14
DJI-Jamie
Flight distance : 112405 ft
PoppaHotel Posted at 2016-12-15 13:11
If the aircraft itself is already updated, that process will be skipped during the update process and only perform the battery firmware packet on the .bin file. It should be a faster process than when the everything needs to be updated. I would recommend preforming an IMU calibration after performing the update to ensure that the sensors are accurate and remove any false messages.
2016-12-14
