Donnie *
Flight distance : 3636782 ft
BerkayGulum Posted at 2017-10-30 03:21
Donnie
Seems that you will be the cure to my problem.. I've got Inspire 1 from a friend. I updated the AC and master RC successfully to the latest firmwares (AC to 1.11.01.50 and RC to 1.7.80). I updated the Master RC via Dji Go app. With Master everything is running flawless. But when I want to update the slave RC I've got a problem. I connected to iphone to update the version via DJi go app but the app did not recognise the RC.
Did the slave work when you first received it and did not update anything ? Or did you try updating everything before testing the entire system .
Are you using the same go app device as the master .? If not try the one you use on the master for testing purposes, we want to make sure it is not simply a failed Go app device or cable.
One of two things is happening here , the Slave is on original FW ( or on a version before 1.3 ) and will need to be updated with update number two and the 1.3 fw update and then you can update normally via the Go app and Internet connection ( wi fi )
Or you may have a filed USB port on the Back of the RC transmitter ( slave ) this is easily replaced and cost about US 100 dollars.
****What color is the first LED light when you turn on the Slave RC ???? Is it like a light blue color or ike a light pink or is it red ???
I would try to update with the first update on the link I am gong to give you , then update to version 1.3 see if one of these two will take . You should get some beeping tones when the process begins . I am going to give you a link on how to update the RC via thumb drive and also some older DJI RC FW files. Keep in mind you only want to update via the USB till version 1.3 , from there you update normally via the go app.
Now if you do the procedure correctly and it still won't install then you more than likely have a bad USB port on the Slave RC.
Let me know what version the Slave Rc was on when you got it from the friend or at the least ask him what version he had it loaded to , If it was past 1.3 then you can assume it is the bad port on the RC slave or the FW got interupted sometime and was not done correctly , there is usually a blue light on the first led of the RC salve , next to the white power lights .
** Keep in mimd I am assuming your friend never updated the RC and thus this is why the go app does not recognize the Go app, If you are past 1.3 on the Rc the is will do no good . :ets assume that you are on the Origianl FW ,load version 1.2.01.06 and see if it will load , if it does great , if not go to version 1.3 and see if it will load , If not then you may have the bad port on the /rc or another problem
RC update via Thumb drive for version RC 1.2 OR Blue Light onRC
inspire_firmwares.htm
**** what gives you the impression the RC transmiter recognizes the go app ??? If you have the "Disconnected " meassage acoss the top of the screen this is just as if the RC is not connected via the cable . Just wondering what you meant by that statemwent . Now if says "Aircraft Disconnected" that would inidcate the RC and Go app are commumicating but the RC tranmitter cannot connect to the aircraft . Let me know hat you meant
Let me know
donnie
