Cannot use phantom3 after MAVIC !!!
1068 8 2016-12-4
indigooo
Flight distance : 178602 ft
After using Mavic I want to fly with my Phantom 3 again but it is not possible to get connected !!!!
Rc Working fine
But the dji go app says disconnected!!!!!
I have a very urgent problem with this
2016-12-4
sailinghappysil
delete and reinstall??? no idea but a place to start.
2016-12-4
Danny-B-
Flight distance : 306640 ft
You dont mention which phone, whether you have exited the app between, what DJI Go app etc etc ...
I suspect you might have to properly exit the DJI go app before launching it again for the P3
It might be worth using the DJI Go 3 app for the P3 and the DJI Go 4 app for the mavic ...
2016-12-4
indigooo
Okay it's Samsung S5
Using the latest Dji go 3.1
What do you mean with exit the app ??
I just closed the app...
2016-12-4
Danny-B-
Use your multitask button and close the app from memory otherwise it holds it in a suspended state and doesnt fully close. but still i'd suggest using the DJI Go 4 app with the mavic and DJI go 3.1 app with the P3
I always open the app first before plugging into the remote instead of setting a default app to open when it detects a connection.
2016-12-4
indigooo
Yes I close the app before totally
I also restarted the phone
And I also reinstalled the Dji app totally new
and I tryto use the 3.1 only forphantom
but no success at all
2016-12-4
indigooo
O. k. Finally I found the Problem.
Taking the risk to stand like a fool... The problem was that I had installed Litchi!!! at the same time
I was aware that some problems were discussed caused by parallel installation
but I didn't have any trouble over a long period using both apps with my p3
but now with Mavic I'm running into it
thanks all and maybe it prevents orthers not to run into this trap
2016-12-4
trance728-
Flight distance : 298048 ft
indigooo Posted at 2016-12-4 16:23
Taking the risk to stand like a fool... The problem was that I h ...
Yea, you just need to go into the Litchi app and clear the defaults so you can connect to the DJI GO app and vice versa, kind of annoying. It's the same if you have both DJI GO apps as well.
2016-12-4
fansebeed138
I had the same problem today with the DJI GO app, I connected my Phone to the RC turned on the RC then the Phantom 3 and the DJI GO app showed as if it was not connected.  I then unplugged my phone from the usb cord then plugged it back in and every thing worked great.
Hope this helps you as well.
2016-12-5
