Phantom Robin
Flight distance : 128839 ft
Belgium
DJI Natalia Posted at 2016-12-6 10:53
Sorry to hear about the issue you are faced with, just to clarify, may I know do you have HDMI module installed?
You have upgraded aircraft and APP to the latest as well?
You could connect your remote to the mobile device, make sure internet is great, run DJI GO, then press the hat for about 5 seconds at the right-upper corner if you use the IOS device, you will get the firmware notification.
DJI Natalia, doesn't DJI have some test devices to have them test this issue, I've been seeing moderators asking that questions a lot after someon complains about the green lines, i my self have them but they disappeared when downgrading my tx to version 1.6. my phantom is running the latest version according to the assistant tool. the grean/pink lines come on different devices android and ios, even when i'm in the middle of no where, tried diffrent cables, and i always fly in airplain mode. clearly its a firmware related issue
http://forum.dji.com/forum.php?m ... D368%26typeid%3D368
