Should P4 owners upgrade to DJI 4.0?
1852 21 2016-12-5
george_007
Flight distance : 183045 ft
Sweden
Hi team!
The subject title says it all. Should Phantom 4 (old non-pro version) users upgrade to DJI GO 4.0?
Regards
Georg
2016-12-5
paul-h
Flight distance : 400817 ft
I tried version 4 and it was very slow, clunky and unresponsive so I uninstalled it and went back to version 3.1, which seems to offer the same features.
Paul
2016-12-5
george_007
Sweden
Thanks Paul! :-)
2016-12-5
Aardvark
Flight distance : 384432 ft
I'm on 4 here (not flight tested yet) but seems to work well on iPad Pro 9.7 & iPhone 6S+.
2016-12-5
Aardvark
Remember it is a different beast from 3.1.1 , not an upgrade so you can have both on your machine and try each one.
2016-12-5
fansb72fe2d6
Flight distance : 101716 ft
I am using it on my Samsung galaxy Tab A and works perfect, better than it did with the original DJI GO. No problems at all
2016-12-5
DJI Natalia
Flight distance : 318 ft
Phantom support both DJI GO 4 and the previous APP version, just as Aardvark said, you can install two different versions in your mobile device.
Please note that, if it not working properly with two APPs installed, you need unplug the USB cable, then go to settings-->Applications-->Application Manager, choose DJI GO 4, and set it as default. If you need use the previous APP, please do the same thing, clear defaults and set the old one as default.
2016-12-5
george_007
Sweden
Thanks Natalia! :-)
2016-12-5
Aardvark
Baldo81 Posted at 2016-12-6 12:31
are we going to see in the DJI GO 4 at least the tripod mode for the P4?
Or is better to stop hoping this on the P4?
Well it's not there yet, maybe 4.0.1 ?
2016-12-6
Grizz 1
Flight distance : 120066 ft
I used the GO 4 app on my P4 on Friday and it flew perfectly, not a glitch. sport mode was good, p mode good, didn't try atti mode or RTH function. every thing very stable.
2016-12-6
fansa84fe8a4
Flight distance : 3 ft
The "Flight Review" part of GO 4 didn't work for me.  That screen only partially loads and freezes the app.  Back to 3.1.1 with the P4.
2016-12-6
TexasTurbo
Flight distance : 1172484 ft
I'm using 4.0 and I like it.
2017-1-7
WindSoul
Flight distance : 16 ft
I installed dji go 4 from the beginning. Got the drone for Christmas. The app works fine on iPhone, I did all initial setup and upgrade, I fly nicely and don't see any disabled  options. It flies well and doesn't feel like something is amiss.
2017-1-8
KenTbk
Flight distance : 327644 ft
Singapore
just notice that is new apps, will try this out and provide feedback on this.
2017-1-10
DJI-Jamie
Flight distance : 112405 ft
While the initial P4 is present on both apps, the Phantom 4 would receive future updates through the DJI Go4 app.
2017-1-10
Capoeira82
Flight distance : 53356 ft
using DJI GO 4.... works like a charm!
2017-1-10
Odan
Flight distance : 182913 ft
DJIGO4 is all Ihave ever known. I have never used the go because when Igot my drone that's all there was for Phantom 4 . So far, no problems at all. I'm using an iPad Air & everything  seems 2B running gr8.   I couldn't be happier
2017-1-13
Testman
Flight distance : 7764088 ft
I'm using DJI GO 4 when I bought the Phantom 4 at 24 december 2016 and works very fine without any problems.
2017-1-14
TJF059
Flight distance : 207064 ft
Im using DJI GO 4 have done right from out of the box since christmas on an ipad air firmware update on both controller and bird.No issues for me.Touch wood
2017-1-14
TexasTurbo
TJF059 Posted at 2017-1-14 18:34
I've tried both really like the interface on 4.0. But after a week using it no problems at all. Then all of a sudden all my Android devices started crashing on loading.
2017-1-14
fansb1fe1104
Flight distance : 3372566 ft
fansb72fe2d6 Posted at 2016-12-5 17:42
I have a Samsung Galaxy Tab A as well, when I installed DJI Go 4 all seemed to work well except for it was either POI mode or Waypoints mode (I forget which one). When I tried 1 of the 2 the app kept crashing or maybe it was the tablet kept rebooting. What a great memory I have huh? Anyways has this happened to you as well? I went back to DJI Go 3 and all seems well again.
2017-1-14
