Just crashed
717 4 2016-12-5
Nm3hGcgJjYs7
Flight distance : 511171 ft
In the process of landing I clipped a tree limb and broke 3 blades. I put on a new set of blades and went back up and everything seems ok. Should I be worried? One or maybe two of the blades were stoped from spinning and a motor message came on the screen. Any tests i can do before to make sure no major damage was done?
2016-12-5
Ange1walk
Flight distance : 30305 ft
Austria
I'd do an IMU Calibration, just to make sure the Acc. and Gyro are functioning properly, other than that check your video feed on how the Gimbal is acting, hopefully it didn't get damaged in the process
2016-12-5
Kneepuck
Flight distance : 275105 ft
a,  check your underwear.  Mine needed changing after a crash.
2016-12-5
Aardvark
Flight distance : 384432 ft
Kneepuck Posted at 2016-12-6 01:17
And for those old enough to remember bicycle clips, a tip, don't remove them ......
2016-12-5
RedHotPoker
Flight distance : 165105 ft
Look in on the blocked motor windings and see if the copper has turned black. If it's still shiny, you likely have very little to be concerned about. Please be more careful in the future. ;-)
RedHotPoker
2016-12-5
