fansc53c1d1e
Pakistan
Roadstar1700 Posted at 2016-12-9 05:56
I had the same problem. After I calibrated my VPS sensor it was back to normal. This is the cal you need to do in front of a computer screen lining up the blue/red boxes. It kept failing at 66% during the cal. I finally tried another monitor and it worked.
My symptom was when I let off the ascend stick it would continue to climb, sometimes 100 feet more, then slowly descend back to where I originally centered the joy stick. When I landed my distance from the ground was way off.
Thanks dear.
I tried it few days back but could not complete that as at some point during the vps calibration, the tracking of the box on the screen was not getting made. It was like a lock at some position and beyond that it was not following the box. I was using my laptop screen so following yours advise I will try the same on some desktop screen.
Keeping a fixed height is critical in my case as I am using my Phantom-4 to scan different crop fields. I have indigenously mounted the following items on my Phantom-4: a multispectral sensor, gps receiver, mounting mechanism, etc. All this payload amounts to almost 300-400 grams.
