Custom settings doesn't work anymore!
1272 7 2016-12-11
flyingasd
Flight distance : 31089 ft
Hi!
When i took my Mavic i immediately changed the controller stick settings.
On the left stick:
Up- forward
Down- backward
Left - turn left
Right - turn right
On the right stick
Up- -altitude
Down- +altitude
Left- left
Right right
I tried some different settings for better flights, but then when i wanted to return to those settings, i can't!
Set up it correctly but doesn't affect controller in anyway.
Why?
Problem with exp, gain, etc... Too. It doesn't save settings.
TIA,
Last firmware for controller and Mavic.
Dji 4 Nexus 5x
2016-12-11
flyingasd
calibrate controller failing. try another times to change the settings but forward is backward... doesn't save anything. a mess!
can i reset everything? where?
2016-12-11
flyingasd
mode 1 or 2, nothing work anymore.
right is right and left is right, up do nothing.
2016-12-11
flyingasd
when i use the flight simulator i can't control aircraft, in mode 1 or 2, nothing works.
the controller failing in every direction.
for lucky this mess didn't happen during flight...
2016-12-11
Since Nexus 5x isn't in our device recommended list. Could you please try to change another mobile device to test?
Just want to rule out if it's the device issue.
If still no work, please make a short video of this issue. I'll help to check it.
2016-12-11
flyingasd
I don't think it's a phone's issue. It worked very nice until i tried to change the stick's sensibility.
2016-12-11
flyingasd
I uninstalled the app, recalibrated controller and everything went ok.
I think the app is so buggy...
2016-12-11
Scoobydude
Seems that some setting you have too turn the GO 4 app off first and the drone because it's saved on the drone.    other's you can turn the drone off first and the app will save them........stuff like changing the exp....shut down app first then restart app and check.
2016-12-13
