zart
Singapore
Received a crashed phantom 3 pro from someone. Cleaned, detach and reattach all cables. phantom able to fly as per normal, no gps issues or whatsoever.
firstly, aircraft able to switch on and warm up. the gimbal will do the usual initilization 'dance'. after a few seconds, the camera died, limp.
problem is, i don't receive any video feed, can't control camera and go into camera menu settings in djigo app. but when i move the camera manually, im able to see the camera tilting from the app.
the next thing i thought i would reflash the firmware and recalibrate. to my surprise, i realise whenever i switch on, there is no blinking green light on the camera status indicator. i insert several sd cards, none of them will read. i reformat using pc and mac, msdos fat format, unzip and copy the .bin file several times and the aircraft wont just update firmware. i tried to look for hidden log file, nothing available. i tried to format using the app, but the app stated 0mb, and i have no other way to format the card thru the app. gimbal status in app shows 'normal'. very weird.
is there any way to rectify this problem? other than send for repair? i can't bear for long turnaround servicing.
