Why does my UI change when i connect my aircraft
7006 13 2016-12-15
visitkans
Flight distance : 80413 ft
I have installed the new GO 4 appWhen i open the app without connecting the aircraft I get the new UI, the moment i power on the P4, ui changes to the old looks and feel
The moment i connect my Phantom 4, the UI changes to the old style and stays that way from then on.
(not my screenshot, just got one from google to show the old UI)
I have uninstalled the app, cleaned up all the folders, even deleted any trace of the dji folders from the Android Tablet.
Tab: Android 6 on Samsung Tab s 8.4
Is there any logic that changes the UI based on the aircraft connected or the tab ui capabilities.
2016-12-15
DJI Natalia
Flight distance : 318 ft
May i know you installed both the old version and DJI GO 4 on your android device or not?
Would you please check the "About" page through the APP, then post a clean screenshot about the page after you connect them properly?
2016-12-15
visitkans
DJI Natalia Posted at 2016-12-15 10:38
initially i had both the versions, had the same issue
then i having both uninstalled both, full clean up of all existing folders that have DJI in them from the android device
and a fresh install of DJI Go 4, still same issue, all is well until tab connects to the remote controller/aircraft.
Will post a screenshot or even a video of what happens and the about page when i get home.
2016-12-15
DJI Natalia
visitkans Posted at 2016-12-15 21:20
Thanks for the details, we'll help you check it once get your screenshot.
2016-12-16
visitkans
DJI Natalia Posted at 2016-12-16 10:05
Thanks Natalia,
Here is a video of what happens, this is from a fresh install after clearing cache and deleting all dji folders from the android file system.
2016-12-16
fans33625b1c
Flight distance : 94446 ft
Indonesia
Same problem with mine.
My go app 4 interface turns into old version when i connect my aircraft.
How to solve the problem?
2016-12-17
DJI Natalia
fans33625b1c Posted at 2016-12-17 21:25
May I know the model number of your mobile device and the system?
It's appreciated if you can make a screenshot of the mobile system page.
2016-12-17
fans33625b1c
Indonesia
DJI Natalia Posted at 2016-12-18 11:21
My mobile device is Asus Zenfone 2 and running on 5.0 android version.
First i'm using dji go app 3.1.0 but still have the problem.
Uninstall the apps and clear default app launcher, install dji go 4, but still same problem.
I installed dji go app to another mobile device (samsung galaxy note 3) which is never got installed dji go app before but the user interface is still old look.
Come on DJI support, give us some useful tips and informations about this issue.
is this issue come from the firmware or dji go or something else?
2016-12-17
visitkans
DJI Natalia Posted at 2016-12-18 04:21
Thanks Natalia,
Tablet: Samsung Tab S 8.4
System: Android
Here are the system page info, let me know if you need any further info. Screenshot_2016-12-19-19-58-08.png
2016-12-19
DJI Natalia
visitkans Posted at 2016-12-20 04:08
Thanks Natalia,
Thanks for the information, the case has been reported, it will be fine for the next version.
Please keep an eye on DJI website, it will be updated once new version is released.
2016-12-20
visitkans
DJI Natalia Posted at 2016-12-20 11:16
Thanks a lot Natalia,
updated to Version 4.0.1 and the UI now seems to stay on in the new style.
2016-12-28
DJI Natalia
visitkans Posted at 2016-12-28 03:47
Very glad to hear that, enjoy it!
2016-12-29
Augustus Brian
Flight distance : 397592 ft
DJI Natalia Posted at 2016-12-29 04:22
DJI-Natalia:
I also noticed this with the 4.0.0 version of the DJI Go4 app. The 4.0.1 version fixed this. Thanks.
It (4.0.1) also restored the ability to save and rerun WayPoints missions, which is also good: Thank you.
However, the DJI Go 4 (4.0.1) still fails to present the WayPoints mission options panel(Consistent with route, Consistent with Plan, Free). When flying, it seems to merely default to Consistent With Route.
This seems to be happening with certain Android devices; I don't think it's an issue with iOS devices.
Keep Smiling,
Augustus
2016-12-29
DJI Natalia
Augustus Brian Posted at 2016-12-29 08:47
DJI-Natalia:
Would you please record a video for us? we'll help you check it.
2016-12-30
