Phantom 4 Pro gimbal issue and internal fan noise
4388 16 2016-12-24
HellStream
Flight distance : 1370771 ft
Finland
Hi there!
I don´t know if this a real issue but the gimbal is making this "click" sound, everytime i turn it by hand and when i turn the drone on and it makes the camera turns the 90 degree angel and over it.
I think this has something to do with the ribbon cable. The noise is coming from the left side of the gimbal where the ribbon cable goes.
And my other thing. First i really didn´t pay attention to it, because i thought it was normal. But after reading comments etc i figured it out that the internal fan is keeping a quite noise. But if i press very gently the shell it stops buzzing. I made a video about it.
2016-12-24
HellStream
Finland
Anyone? DJI Natalia, can you please read this and give a comment. Should i return my unit?
2016-12-25
Punchbuggy
Flight distance : 573054 ft
HellStream Posted at 2016-12-26 00:06
I can't say anything about the gimbal issue, but the fan noise could be the internal fan resting against the inside of the shell. pushing on a part of the shell may be flexing it off the fan. There's a thread here somewhere with pictures of the internal fan (someone actually opened the P4P up to see - a bit silly, but hey...).
2016-12-25
G Davidson
Flight distance : 263465 ft
Punchbuggy Posted at 2016-12-25 23:29
[sorry I meant to reply to the original poster]
If you look carefully at your first video, you can see the ribbon cable creeping into view (in the gap between the gimbal bearing on the left  and camera body) and snapping back into place with a click. Perhaps the cable is folding back over itself before snapping into position.
If that is the case, it would lead to added resistance to movement when the camera is pointing straight down (might even lead to gimbal overload errors in some situations) and also unnecessary wear and tear on the ribbon cable. I wonder if this affects many P4 Pros or if there are variations in how the ribbon is fitted and it only affects some of them.
2016-12-25
HellStream
Finland
This picture tells it all. The ribbon cable is rubbing against the camera body.
2016-12-25
Tinyhousebasics
Phantom 4 pro gimbal not responding after controller firmware update.
I have about 7 flights on the p4p and after my last flight yesterday I updated the firmware per the apps request. I tried to fly the drone today and zero response from the controller. It will connect and take off but the gimbal just stays linp and you can't raise it up.
Anybody have any suggestions to help fix this issue?
I tried selecting auto calibrate gimble in the settings but it's does not do anything. It was just say "start gimbal calibration 6%, don't move the aircraft' and it will stay on that screen
2016-12-25
HellStream
Finland
Tinyhousebasics Posted at 2016-12-26 03:40
Downgrade your firmware and try the gimbal calibration again.
2016-12-25
Rtheo
same issue here, terible fan noise and when pressing on shell it changes...return or keep?
2017-1-10
Marjanko
Flight distance : 647372 ft
Austria
Rtheo Posted at 2017-1-10 02:31
Me too. Just unboxed .... turn it on.. and .there it was that terible noise
What to do??
Did you write to DJI ?
2017-1-27
method007
Flight distance : 110449 ft
Mine is the same way.  Loud fan that gets less loud when you push on it.  Almost like it's slightly touching the case.  I sent a video to DJI and they told me the noise was normal.
2017-1-27
Marjanko
Austria
I send the video too. I sended my p4p proplus back.
2017-1-29
fans5d92ba28
Ok guys I had yhe same problem with the lout fan noise. It seemed as if it was rubbing against something which I believe would lead to early wear and tear issues with the fan. BUT THE NOISE IS NOW GONE! It was a really easy fix too. All you have to do is SLIGHTLY adjust those srews that attach the gimbal cover to the drone. (The gray part). I used a small allen wrench (Size 1.5mm) and tightened them a tiny bit and noticed it did not inprove so I loosened them a TINY TINY BIT AND BOOM! The noise is gone! Let me know if thos helps you all too. I am confident it will.
2017-2-7
fans5d92ba28
Ok guys I had the same problem with the loud fan noise. It seemed as if it was rubbing against something which I believe would lead to early wear and tear issues with the fan. BUT THE NOISE IS NOW GONE! It was a really easy fix too. All you have to do is SLIGHTLY adjust those srews that attach the gimbal cover to the drone. (The gray part). I used a small allen wrench (Size 1.5mm) and tightened them a tiny bit and noticed it did not inprove so I loosened them a TINY TINY BIT AND BOOM! The noise is gone! Let me know if this helps you all too. I am confident it will.
2017-2-7
Marjanko
Austria
got a brand new dji phantom 4 pro plus.
2017-2-11
Daniel T
Greece
Same issue with P4 advanced. ipPumba@yandex.ru please send me a link to update and instructions. I'm on vacation now and i have only few hours to capture this beautiful place, hope so much that you'll try to help me as soon as possible
2017-8-29
ALABAMA
Flight distance : 10442687 ft
fans5d92ba28 Posted at 2017-2-7 22:41
Good eye!  I would keep a check on those screws tho, since vibration could make them work out.
2017-8-29
rolsch_p4p
Flight distance : 46834 ft
Tinyhousebasics Posted at 2016-12-25 17:40
Same Problem (solved): update aircraft to 01.04.0602.
http://forum.dji.com/forum.php?m ... id%3D386&page=1
DJI Support delivered me an beta firm 01.04.0608 and this fixes the problem.
Update comes over the DJI assisst tool and the reg. DJI mail-account...
2017-8-30
