Problem with video vibration
825 8 2016-12-25
MsTron
Hi!
When my Phantom 3 are flying and still the recorded image have very vibrations.
You can see here :
Can anybody tell me any support?
It is a new phantom 3, have only 2 days.
Regards!
2016-12-25
Aardvark
Flight distance : 384432 ft
Two things to check:-
1) You only have two anti-drop plastic pins fitted ?
2)there are no packing pieces above camera still to be removed ?
2016-12-25
MsTron
Thank you for the response.
- Only 2
- All the packing pieces are remove.
2016-12-25
Betamace
Flight distance : 2133 ft
Jello. The rotors need balanced or  #2's comment.
2016-12-25
MrPinaColada
Flight distance : 790082 ft
Try using the spare set of props. The jello could be from unbalanced props.
2016-12-25
Betamace
MrPinaColada Posted at 2016-12-26 11:09
Oh,  it only started right after the firmware upgrade LOL
2016-12-25
DJI Natalia
Flight distance : 318 ft
We saw your another thread for the sound, you've done all the methods mentioned above, right? may I know the performance now?
2016-12-26
Asparuh Nestoro
Flight distance : 195456 ft
Bulgaria
Your gimbal is not working properly. I have almost the same problem although my jello seem a little bit less but nothing I tried helps (balancing propellers, calibrating). I do not want to do something major in order not to loose my guarantee.  You'd better return it while its not too late. I find a lot of complains about vibrations (jello) among all versions of phantom 3 and most of them returns the phantom or just do not use the video. It seems that the quality is not as good as DJI advertise and its a matter of luck to get a drone working well.
2016-12-26
MrPinaColada
Betamace Posted at 2016-12-26 02:03
Which firmware are you running?
2016-12-26
