Constant Firmware updates
1650 8 2016-12-27
AIRRAGE
Is it normal that I get firmware updates everyday and sometimes everytime I shutdown and fire back up? Seems excessive.
2016-12-27
DJI Natalia
Flight distance : 318 ft
Please help clarify your aircraft model and check the current firmware version on "About" page through APP.
What mobile device you are using? how about the APP version?
2016-12-27
AIRRAGE
DJI Natalia Posted at 2016-12-28 12:16
I have the P4 and I am using the iphone5 with the latest DJI GO app.
2016-12-28
DJI Natalia
AIRRAGE Posted at 2016-12-28 06:28
Please delete the APP and re-install it then check again.
Also you can change another mobile device to connect the aircraft if convenient.
If the message persists, please upload a screenshot of the firmware version on "About" page.
2016-12-29
fans40deff10
Flight distance : 153130 ft
Thailand
I'm having the same issue!! Literally everyday there is another update and my drone won't fly without the update! Incredibly frustrating since I traveled across the world to fly my drone and everytime I want to put my drone in the air (after just completing a firmware update) I am hit with another update and i'm nowhere near wifi to do the update before my perfect sunset goes down!!!!!!!!
2017-11-2
DJI Diana
Flight distance : 2408 ft
fans40deff10 Posted at 2017-11-2 03:10
Which drone are you referring to? What is the current firmware version of the drone? Is it up to date?
2017-11-2
Briezway
Thailand
DJI Diana Posted at 2017-11-2 03:26
I have the Mavic Pro and the SPARK. Same issue with both. Just now I was adjusting the setting on my Mavic. My phone battery was low so I disconnected it to charge it up. When I reconnected it I had yet ANOTHER update to do!!! I swear I did this update already (GPS update). Jesus, really? If I had been out flying and stopped to charge my phone, I would've been screwed trying to capture any more footage because unless you update, your drone doesn't fly!
2017-11-2
DJI Diana
Briezway Posted at 2017-11-2 06:14
Please refresh the firmware via DJI Assistant 2, then reinstall the App, see if it helps. If it persists, please provide a screenshot of the error message and a screenshot of the "About" page.
2017-11-2
Antonio76
Flight distance : 144403 ft
Denmark
What's a GPS update? Never heard of...
2017-11-3
