Aardvark
Flight distance : 384432 ft
When you power up RC & aircraft do you see green LED on RC ? If green then RC is communicating with aircraft, but it might be a good idea to try reset and relinking the RC to the aircraft (similar to Bluetooth pairing).
Try to reset the RC:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter (top right button nearest antenna) on the controller and hold until it beeps, then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
I would recommend manually relinking the RC by performing the following;
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button (top left button) on the controller, then the controller will beep like D-DD.
*Let go all fingers, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
Once done check if you can connect to aircraft using DJI Go, if it says 'disconnected' then try repowering RC.
