AerialZ
Flight distance : 52638 ft
Geebax Posted at 2017-1-1 14:12
My guess is that the gimbal servo system is poorly adjusted, that is the sort of thing that causes the buzzing noise you mentioned, and it also explains the vibration of the camera, apparent in the video clip. But it is not something you can adjust yourself, hence my suggestion to exchange it.
I just received the replacement P4P and after a quick bench test, the previous problem is gone. The gimbal noise of the first P4P is absent, only the high pitched whine of the fan. Hopefully no one else sees these issues right after unboxing. If you're hearing any clicking or metallic noise from your gimbal, you definitely have an issue. This replacement also ran an immediate gimbal calibration where the previous hung on 6%.
I'm looking forward to getting it in the air! |
