Geebax
'There is a lot of rubbish posted about formatting cards etc. - unless your card is not recognised DO NOT FORMAT !! '
Would you like to explain why? Apart from anything else, if the card is not recognised by the aircraft, you cannot format it anyway.
Formatting is a good way to manage the contents of the SD card. Apart from the storage used for photos and video files, the aircraft writes a lot of lengthy files to hidden directories on the card, and it will fill up quite quickly while at the same time, leaving the owner puzzled as to where the storage went. Formatting clears all the files and re-initialises the directories, leaving the SD card with the maximum space for storing material, and it does absolutely no harm to do so.
