How to remove your battery easily !
1315 4 2015-2-16
rdsb
Flight distance : 236230 ft
Hello.
The batteries of my new PV2+ were quiete hard to remove.
So, I used an electronical lubricating spray, on the sliders of the batteries. Removing them 3 times, then using some more spray on the sliders.
I can now remove a battery from the Pv2+ more easily !
You can also use a teflon spray, a silicon spray, or some parrafin wax (candles, jam pots, ...)
Do not lubricate the phantom's sliders, just in case !
View from the PV2+ battery compartment
Note that the cables are protected against interferences (cylinder magnets) - I do not loose any satellite when starting recording a video.
And removing the battery could hardly damage those background multiconductors cables.
Amicalement.
2015-2-16
nilsblix.gmail
Flight distance : 23047543 ft
Hello
The batteries on a new Phantom is and should be hard to remove - learn the right technique and it become more easily removable. Do a search on Youtube and you will find how to easily remove batteries - it is simple. I would not lubricate as it collects dirt Here is the video
2015-2-16
rdsb
nilsblix.gmail , I could not remove the battery as shown on your video : it was much harder and I had to move it millimiter by millimiter, left and right, within the 1st centimeter, even using the motor arms to help my hands. I would say that after lubricating, it's a bit harder than on your video.
Cleanning the sliders from dust is an easy step, I will do it from time to time.
But thank you very much for your valuable comment.
2015-2-16
Daninho
Flight distance : 70203 ft
agree, those batteries need to be removed with the right technic as seen above.
2015-2-16
gnixon2015
the method in the video works perfectly for me, no yanking and they slide out well.  it also helps prevent pulling off the battery faceplate.
2015-2-16
