How to focus camera
1986 12 2017-1-21
Nick823
Flight distance : 4911 ft
Stiill new at this, first time I tried to use camera.  Is there an auto focus or do you have to tap to focus.
2017-1-21
dbgrn
Flight distance : 661791 ft
You have to use tap to focus, although if you're using the newer DJI Go 4 app, it will auto centre focus for you from time to time (typically when the Mavic stops moving).
2017-1-21
Nick823
dbgrn Posted at 2017-1-21 14:37
I took a bunch of pics, mostly blurred somewhat.  Do I have to wait longer for the app the adjust
2017-1-21
Watty2000
Flight distance : 1074301 ft
Nick823 Posted at 2017-1-21 14:49
Tap on the screen where you want the image to be in focus. I focus way in the distance then select MF (manual focus) to lock it.
2017-1-21
Nick823
Watty2000 Posted at 2017-1-21 14:54
Are you able to resize the square box or do you have to maneuver the aircraft to fill in box, then use manual focus
2017-1-21
Nick823
Would this be for the DJI 4 app, that's what I am on
2017-1-22
Nick823
Yes using DJI 4 now
2017-1-22
Nick823
Normally wouldn't you want the entire frame area to be in focus, if that's not the case, I would think you would want everything in front in focus.  Shame you can't resize the green square and lock it.  I will try locking to manual after it auto focus, then should it stay completely in focus if it's directly centered in front of me.
2017-1-22
BentonJoyce
Flight distance : 234318 ft
Something that helps me with focus is I use the programmable buttons on the back to center focus it just makes it easier than touching the screen. I like keeping my hands on the remote as much as possible.
2017-1-22
Nick823
BentonJoyce Posted at 2017-1-22 21:33
So anything in the green square will be in focus and never nothing around it.  I guess maybe need to concentrate on the center of screen and pay more attention to location of the focusing point.  I don't know if I should let it focus itself or tap to focus.
2017-1-23
Dronoob
Flight distance : 126079 ft
There is a difference if you are on iOS or Android. Everything about focus in the current version of DJI Go 4.0 can be read at Mavic Pro Focusing Clarification - Comment #2
2017-1-23
Nick823
Dronoob Posted at 2017-1-23 01:20
Ok,  I will check it out.  I am using Android
2017-1-23
Nick823
Does the auto focus without tapping only work in flight?
2017-1-24
