Remote cable comes out of the clip when removing phone from contr...
1853 13 2017-1-24
fans464c96e6
Anyone using a nexus 6p phone with the mavic remote. It seems the USB C connection is tight and when I remove the phone the cable comes out of the controller clip.
I'm pretty sure I installed the USB c cable and the little square bracket correctly in the remote.
2017-1-24
Jenee 2
Flight distance : 7852129 ft
Yes, another irritation you have to put up with on the Mavic. Same thing happens to me but you just need to use your fingernail under the clip to hold it while removing the phone or slide the clip to the outside and hold pressure while gently removing the phone.
2017-1-24
ay6810
Flight distance : 76631 ft
Singapore
Can I ask if your set came with the USB C cable or you had to purchase one separately?
2017-1-25
Peter Galbavy
Flight distance : 545377 ft
I thought there were two sizes of clip for different cables? Perhaps you have the larger one in place (for the iphone I think) ?
2017-1-25
devGOD
Flight distance : 200577 ft
just put it back in
2017-1-25
fans90d4f438
Flight distance : 451335 ft
That's what she said
2017-1-25
fans464c96e6
im using the USB-C cable that came with the mavic. Now that cable pouch did have two plastic adapters that install into the RC. I dont know whats the difference between the two adapters? They must be the same, i dont see the point in them being different becuase they are to be used with DJI's USB-C cable.
2017-1-25
fans464c96e6
Has anyone tried shaving some of the plastic from the controller so that a phone would slide in easier..... (No that is not what she said!!!!)
2017-1-25
P3T3
Flight distance : 701211 ft
fans464c96e6 Posted at 2017-1-25 10:08
Contemplating doing this. Using iPhone with included pre-installed cable and having this problem. At first it was ok, but once it did it one time it's happened every time since. Annoying
2017-1-25
fans464c96e6
P3T3 Posted at 2017-1-25 10:39
yeh im finding that putting phone  in the controller and setting it up takes about the same time it did for me to setup the props on the phantom 3 and getting it ready to go. So what ever time i save with the mavic for that, i waste on setting up the controller now.. LOL
2017-1-25
fans464c96e6
I do want to find a solution to prevent the usb cable from popping our of the controller clip though..thats extremly annoying.Maybe i should just use super glue or hot glue on the clip so that it stays in there for good!!
2017-1-25
P3T3
fans464c96e6 Posted at 2017-1-25 11:15
I might go with the hot glue seeing as it's easily removed without any potential for damage like you may encounter with super glue.
2017-1-25
thehippoz
Flight distance : 23 ft
I use this because the micro was upside down. It fits from the bottom connector without extra cable flopping https://www.amazon.com/gp/product/B01FA4JXN0
2017-1-25
fans464c96e6
P3T3 Posted at 2017-1-25 20:11
Yeh, I already did that yesterday. Seems to work fine now. I also shaved off some of the rubber grip in which the phone slides into the controller. My Nexus 6P device is thicker on one end so it would not go in at all. Shaving off about 2mm did the trick.
2017-1-26
