Prop blade kink/bent?
1022 10 2017-1-25
Ely324
Flight distance : 904888 ft
My Phantom 4 Pro has been having this weird drift to the right, which is most noticeable when the aircraft is pitched forward and rolled to the right and then going back to just a forward pitch. It feels like the drone wants to stay moving to the right as if it was rolled to the right still.
After inspecting the props, this is what I found. I'm guessing this would be the reason for this?
bent blade
bent blade
2017-1-25
ProQuad
Flight distance : 20296870 ft
Possibly.  Just replace them and that should help.  Props are not that expensive.
2017-1-25
RedHotPoker
Flight distance : 165105 ft
You could let that bent prop sit in very hot water a couple of minutes and then carefully reform its original shape. ;-)
RedHotPoker
2017-1-25
DJI-Jamie
Flight distance : 112405 ft
I would recommend replacing the props. If you really want to salvage it, you can try RedHotPoker's approach, but you would want to be mindful if they bend again. Did you have any hard landings?
2017-1-25
RedHotPoker
DJI-Jamie Posted at 2017-1-25 21:56
I would recommend replacing the props. If you really want to salvage it, you can try RedHotPoker's approach, but you would want to be mindful if the bend again. Did you have any hard landings?
Using a heat gun, gently, might be a good method as well. Just be careful not to burn the blade or your fingers. ;-)
RedHotPoker
2017-1-25
Cetacean
Flight distance : 2528264 ft
Aloha Jamie,
     Storing them under pressure can easily cause them to bend.  Even the RC sticks in a traveling case.  You have to be sure the sticks are screwed all the way down so they so not touch the sides.  Otherwise you will have to do a RC calibration.
     You really have to be careful when packing and storing these parts.  Light pressure over time creates problems with warping.
Aloha and Drone On!
2017-1-26
RedHotPoker
Cetacean Posted at 2017-1-26 01:05
Aloha Jamie,
After Reading this, I I might have to take a few sets of new unused props out of my Nanuk 945 case, and store them on my RC workbench. ;-)
Not looking for any trouble...
RedHotPoker
2017-1-26
Ely324
I decided to just swap it out with a new one. No point in taking a chance of crashing mid flight due to a damaged prop. I was mainly wondering how the prop got bent, as someone mentioned earlier it was probably due to pressure on the blade in the storage case. I'll have to be more careful when storing them in the case.
2017-1-26
DJI-Jamie
RedHotPoker Posted at 2017-1-25 22:07
The latter would be more important.
2017-1-26
DJI-Jamie
Ely324 Posted at 2017-1-26 09:12
Good to hear.
2017-1-26
RedHotPoker
DJI-Jamie Posted at 2017-1-26 10:38
Yes, please be careful. It would be a shame to read about an accident, that could have been prevented...
RedHotPoker
2017-1-26
