RTH Not working
729 5 2017-1-29
StefanoRem
Flight distance : 323225 ft
Belgium
Hi guys,
My RTH is still not working... when i click the return home button, it only goes higher. Everything is ok with the drone; latest firmware, right RTH settings, everything calibrated and so on. The drone just don't move horizontally towards me, it only goes very high like 140meters...
Someone knows what the problem is and how to fix it?
thanks a lot!
2017-1-29
Mark The Droner
Flight distance : 2917 ft
What happens when it gets to 140 meters?
Sounds like you might have set the RTH height higher than the maximum height allowance setting?  Just guessing.
2017-1-29
StefanoRem
Belgium
Mark The Droner Posted at 2017-1-29 05:44
It just keeps going higher! Nothing happens.
And no, my RTH height setting is only 40 meters. Thats why i don't understand why he keeps going higher.
2017-1-29
Mark The Droner
I've read tens of thousands of posts over the past 18 months and I've never heard of this problem...
You might try an IMU calibration.
If that doesn't help, I'd contact DJI.
2017-1-29
StefanoRem
Belgium
Mark The Droner Posted at 2017-1-29 07:22
Okay i will try and let you know. Thanks for your time
2017-1-29
StefanoRem
Belgium
Works!! IMU Calibration did the job!! thanks!!
2017-1-29
