Wide angle lens
4761 3 2017-1-31
EmilioCid
Flight distance : 7445200 ft
Brazil
Is it possible to attach an Wide angle lens to the Mavic to get the same view angle of the Phantom. Years ago I did it successfully to an Aiptek cam.
Thanks
2017-1-31
StigNygaard
Flight distance : 357169 ft
Denmark
To my knowledge nothing like that is available to the Mavic. I also don't think it would be possible to make, because the lens would be too big for the gimbal initialization process to work with the addon-lens attached.
And just for the record, the current Mavic lens is also already regarded as a wideangle lens. But, no it is still not as (ultra)wide as those on the cameras of earlier Phantom drones.
2017-1-31
cluc
Flight distance : 85682 ft
The only issue is that, will your wide angle lens work for:
  • During gimbal initialisation. (Obstruction, Weight, etc)
  • Cuase any reflections, glare, etc.
If it works like those after market filters, then you should share what lens you are using. :-)
2017-1-31
Migue_alex74
cluc Posted at 2017-1-31 18:59
  • I don't see why it would not work after initialization. I.e Polarpro filters are attached right before take off, so they clear the initialization. But a fisheye could be used instead of their nd filters
    2017-1-31
