DJI-Jamie
Flight distance : 112405 ft
peecee Posted at 2017-2-15 23:49
I haven't as I don't want to damage it and I didn't want to turn it on and take the plastic off incase there is an issue.
The mount looks central its just bent at an angle, everything seems flush and tight.
It was most likely skewed during manufacture. If it had been dropped, there would most likely be stress on the metal and there would be visible damage to the screen itself. You should be able to turn it on with the wrapping on, just to check if it works. If the amount of skew is going to bother you anyway, you're better off getting and exchange with your dealer (if you're still within the exchange period for them).
