rick39
Flight distance : 164354 ft
This may be different to your IOS version, but here goes.
You don't need the drone or controller to check your flight data. Open up the DJIgo 4 app on your phone/tablet. Choose the Mavic Pro as your preferred drone if it doesn't default to it. Along the bottom of the screen reading left to right there are four icons starting with "Equipment". Above that it should read "Disconnected", and above that is an arrow pointer/radar icon. Tap that icon.
The screen will open with a list of statistical data showing top distance, speed and altitude you've achieved. Below that should be listed all the flights you have made to date. Scroll down to show the flight you might be interested in and tap it. This opens up the map view showing the start of when the drone was turned on and synced with the controller. This is a recording of that flight which can be played through and will show the course the drone took as an animation on the map. Apart from the data you see at the top of the screen, any warnings that were made will appear at the time they did during the flight. Tap the controller icon at the bottom of the screen to overlay stick movements that were made during the flight. To view another flight exit the screen with the "X" icon top left and choose another record OR use the arrow keys at the top of the screen on the left hand and right hand sides to sequentially load the next flight.
Hope that helps. |
