SwedishDrone
Sweden
Yesterday I was about to fly over a bridge, and as I looked at the drone, I could se a rather large crack on it, and when I looked closer, I realized it was not a crack on the actual drone, but a crack between the battery and the drone. The drone started and everyting was ok, but the battery was actually not in the correct position. It was rather loose. I imagined it falling off when I would be above the water - rather dire consequenses. Just a warning, make sure the battery is attached correctly, and you can hear the "click"...
Good luck everyone!
