Nigel_
Flight distance : 388642 ft
If it is down to 95% then it has presumably started the self-discharge. The problem then is that the 95% figure is not all that accurate and there is a very small possibility of it running out of power before it lands.
If you can, give it a top up, otherwise land a bit early, don't use it down to 10%.
The only problem with leaving it at 100% and not using it is that it reduces the batteries capacity/lifespan a little, if you keep it at 100% all year long then you will loose a significant % of lifespan over the year, a day or two you wont ever notice. For a long life it is better to store it at around 50%. This isn't a safety issue. |
