Export/Import DJI Go 4 settings (feature request)
1245 2 2017-3-4
michaeln416
Flight distance : 595157 ft
I would like to have the ability to export and import settings into the DJI Go 4 app.
There are a few typical scenarios that I regularly fly & record in that each has their own unique setup; Mavic, gimbal & camera. I would love to have the ability to export these and save them on either my mobile device or the Mavic's SD card. I can then name them something meaningful and apply a date stamp. After that, each time I need that group of settings I can simply import it, ensure that it is still compatible with any new firmware updates then apply it.
This would save time and battery power at the beginning of each flight.
Mike
2017-3-4
DRONE-flies-YOU
Flight distance : 1638323 ft
That could be dangerous betting that the info imports & exports successfully.  Manually applying settings also serves as a double-check of the systems, which is a good thing.
Another option could be to add tabs with your different settings.  So you have 3 configurations:  1 for each type of gimbal/camera setup.  (DJI GO 4 implemented)
2017-3-4
dronist
You can have setting for the camera and gimbal but would stay OUT of the MP like DRONE says you better double check your settings manually.
2017-3-4
