Replacement Drone
1048 12 2017-3-30
zeekman
Flight distance : 696506 ft
Has anybody gotten a replacement drone from a flyaway under warranty? DJI won't warranty mine because they say there was no info on what happened to mine in the flight logs.
2017-3-30
RicardoGray
Flight distance : 4356421 ft
I can't say as I blame them. I mean if there is no evidence of what happened, why would you feel obligated to replace the product? There are flight logs, and it should record all activity. Hey, I feel for you, really. And I'm sorry for your loss, but it sounds like one of those bad situations. You might post you logs to http://www.phantomhelp.com/LogViewer/Upload/ and see if someone else could analyze your data.
2017-3-30
DJI-Ken
Flight distance : 1515312 ft
What is your email used with the GO app and I can review your flight.
2017-3-30
Callatis
Flight distance : 511112 ft
Were you using any other app than DJI GO?
2017-3-30
zeekman
DJI-Ken Posted at 2017-3-30 10:21
My Email is gnosko@sympatico.ca  There where three flights on that day March 16. RTH worked fine on the first two but did not RTH on the last flight after signal lost. Check my thread started on March 22
2017-3-30
zeekman
Callatis Posted at 2017-3-30 10:30
I was using DJI Go app
2017-3-30
zeekman
RicardoGray Posted at 2017-3-30 10:20
Here is the flight log  [url=http://www.phantomhelp.com/LogViewer/Y4Q0VXZMTFKQUMJCFC74/   The drone should have RTH but did not.
2017-3-30
Mark The Droner
Flight distance : 2917 ft
(courtesy of msinger)
Are you sure it didn't hover and auto land where it was?
How was the wind that day?
2017-3-30
DJI-Ken
zeekman Posted at 2017-3-30 11:05
I just looked at your flight and I think something hit your aircraft.
You were just about at 600ft and you can see at the very end there is a violent spin then nothing else is recorded.
If you play back the flight in your flight records you can see the same thing.
If it had lost a prop it would still record but it just ends immediately after the violent spin to the right a full 360.
2017-3-30
zeekman
DJI-Ken Posted at 2017-3-30 11:16
I was spinning the AC filming the area.  I did not see anything hit the aircraft. Where did the AC go? It should have RTH after losing signal.
2017-3-30
DJI-Ken
zeekman Posted at 2017-3-30 11:28
Look closely at the last second of the recording, it was a violent spin to the right more than 360° and there was no stick input from you. The entire spin was a fraction of a second, the aircraft cannot turn that fast on it's own.
You were almost almost 1,500ft away from the aircraft, and it looks like it lost signal because it was hit therefore there is no RTH.
2017-3-30
zeekman
DJI-Ken Posted at 2017-3-30 11:38
Where would the AC have gone? I searched the whole area and could not find the AC. I would have seen it drop out of the sky since I was walking toward it when I lost signal.
2017-3-30
DJI-Ken
zeekman Posted at 2017-3-30 11:47
I don't know, you were 1,500ft away, that's a pretty far distance to see something the size of a Phantom.
I'd go look on the roof of the corner house on Woodland and Rose$%#$ or in that vicinity.
2017-3-30
