KM5RG-Robert
Flight distance : 2075213 ft
It seems to me that if you are not aware of the differences in the props (hub colors), you need to get more familiar with the aircraft and manual before flying. The props on alternate corners have different threads and blade pitch (they rotate in opposite directions in use).
The CSC command (look it up in the manual) is the way to shut down the motors in an emergency except I have heard that it may not work when the AC is inverted such as yours was. In your situation I would probably run over, grab the AC and pick it up off the ground/flip it over to free the motors and then shut the battery down as a first choice or pull the battery as you did. Not sure if pulling the battery when powered up could cause any problems with the electronics. |
