DroneFlying
Flight distance : 10774613 ft
What is the best thing to do from here?
Have it repaired. You mentioned a gimbal failure, but that would be the least of my concerns. If sand also got into one or more motors -- and there's a good chance that it did -- then you could have a mid-flight failure with serious consequences.
If you bought Care Refresh then you should be able to use that to get it repaired (or more likely replaced), but in any case I wouldn't be flying it again as is. |
