fansfb8052f3
Flight distance : 25013 ft
Had my Mavic for two days. Did a few flights.... was very happy with it!
Took it to our firing range to get some video of students in a training class. The range is relatively remote and has no WiFi or other RF sources.
Flew around 1130 AM in the open area of the range and had no issues. There is also a large, wooden, "pole barn" that covers the range out to about 25 meters. The sides are open, and the back has wooden barn doors that slide and stack in the middle. These were also open. During my early flight, I poked under the covered area to get some footage of the students. Landed it ok and all was well.
At lunch, I was going to test how it flew under the covered area (the roof is probably 25 or 30 feet high) to see if I could get footage of the students from behind.
I took off in the open and as soon as the drone got to about 20 feet, it lost connection with the RC (the RC said "connecting"). I shut down the RC, regained connection and landed. Turned everything off and tried again. I posted a screenshot from healthy drones of that one.
Anyway, took off again and everything was going great. I had a brief loss of connections (between controller and RC, again) but it resolved itself. I kept the drone over the range for the next couple minutes and everything seemed fine. I flew it out over the adjoining ranges, and everything was working.
I felt satisfied that it was flying OK, so I very slowly flew down the side of the "pole barn" to the targets on the range, and then started making my way back to me. At this point I was standing to the right of the homepoint as pictured below. I could see the drone clearly under the covered area. I was at the 35 yard line, and the drone was making its way back to me. The last datapoint from healthydrones shows that it was about 100 feet away at a height of 11 feet. At about the 10-15 yard line, it lost connection with the remote again. It started to initiate its RTH sequence. I ran up to it to try and reconnect....but not before it climed into the ceiling and destroyed itself bouncing between the trusses. Down it finally fell in a heap. It is very messed up.
So. First lesson learned is that I should have adjusted the RTH protocol to hover before I went into the covered area. I will own that one.
That said, I am a little put off that it lost connection with the remote at 100 feet, with clear line of sight, in an area with no RF sources to speak of, and under a wooden structure.
I have DJI Refresh, and the drone has been sent back for repairs. Sadly, I did not download the info from the drone before I sent it. I know DJI will, and I hope that it is illuminating as to why I kept losing connection.
I am hoping that the connection issue will be resolved as a warranty problem as opposed to using one of my "refreshes." Again, however, I own the failure to compensate for the RTH setting. I see there is a little bit of precednece for this.... https://forum.dji.com/thread-71105-1-1.html
Moving forward - what are some steps to troubleshoot the loss of connection issues? I didn't get any warnings that there was RF interference, or any other indicator of calamity until it happened.
I appreciate any constructive input.
