controler bleeps
693 5 2017-4-30
fansda62c1a8
stick err re-ctr stick { bleep bleep bleep } for 5mins or longer can not stop this   what is this and why new out the box
2017-4-30
Kenwae
Where are you powering it on? Could be obstacles, interference. Move to another location in an open space and see if that helps....
2017-4-30
hungdang
Flight distance : 4931706 ft
Calibrate your controller will solved your problem.
2017-4-30
way wrong
Flight distance : 351631 ft
Estonia
You need to do remote controller calibration to calibrate sticks thru the DIJ Go 4n app. Menu > Remote Controller Settings (remote logo) > Remote Controller Calibration.
2017-4-30
Jeromeo
Flight distance : 103369 ft
Before calibrating make sure the sticks are properly centered. If it bleeps at you when turning on the remote the stick could be sticky. I have my Rc in repair because of this....
2017-5-1
Is the problem fixed after the RC calibration?
2017-5-4
