.17 Single Stick Shutdown No More?
1437 10 2015-3-6
stevejg16
Flight distance : 29001916 ft
After my upgrade I can't do a single stick motor shutdown. I'm assuming they changed this because some people may have been shutting their motors off mid flight.
I'm just checking to make sure this is part of the .17 upgrade.
How about yours?
2015-3-6
markjacobs.talk
Flight distance : 120784 ft
Single stick shutdown fine here on .17
Flew 4 packs yesterday on new firmware and single stick shutdown worked every time. Single stick shutdown will not initiate while you are flying and the flight controller is getting difference readings from the barometer.
Maybe try RC calibration as remote may not be seeing full throw of the throttle stick after upgrade.
2015-3-6
stevejg16
markjacobs.talk Posted at 2015-3-6 22:03
Flew 4 packs yesterday on new firmware and single stick shut ...
Oh boy, and I just got this back after 5 weeks at DJI LA (not a crash repair).
And yes, I did an RC Calibration. I'll try another one tonight.
Anybody else have an idea what may be going on here?
2015-3-6
Blade_Strike
Flight distance : 872694 ft
Once on the ground you should be able to bring throttle down and hold it for a sec or two, this will shutdown the motors.
2015-3-6
yiassemis
Flight distance : 690197 ft
Cyprus
If you turn the motors on, you won't be able to turn them off with throttle down, if you don't lift it. You have to shut them down with both sticks. Again, I'm talking the bird is on the ground all the time.
Andy
2015-3-6
stevejg16
Blade_Strike Posted at 2015-3-7 00:19
Once on the ground you should be able to bring throttle down and hold it for a sec or two, this will ...
Blade_Strike.  No, I can't, I have to do a csc shutdown. Any suggestions?
2015-3-6
stevejg16
yiassemis@cytan Posted at 2015-3-7 00:58
If you turn the motors on, you won't be able to turn them off with throttle down, if you don't lift  ...
Andy, I just got the unit back but, hovered in the house a bit, then landed and the single stick down and hold would not shut the motors.
2015-3-6
yiassemis
Cyprus
That's weird... Are you sure your sticks are calibrated?
Andy
2015-3-6
Blade_Strike
Was this over carpet by any chance?
2015-3-6
stevejg16
Blade_Strike Posted at 2015-3-7 03:37
Yes, it was but, I have flown over this a dozen times before I sent the unit in to LA. I'll try another surface later tonight if you suspect that may be a problem.
2015-3-6
CrabHawk
Flight distance : 7782 ft
mine shuts down with both 1 and 2 sticks.
2015-3-6
