CannotTakeOff
What you describe is how it always seemed to me. But after I updated everything recently I was getting a lot of 'cannot take off' messages, especially if I was indoors messing around or outside under trees where gps signal was slow to lock on.
Finally I seemed to trace it to the initial satellite locks. It will not allow motors to turn on until ~7 or 8 satellites lock. In these conditions that may take some time. Much more than just warming up.
The 'cannot take off' notice goes away immediately when the 'home point location set' message sounds. This all coincides with getting enough satellites, so it may not exactly be the home point being set that is a requirement, but some sufficient amount of satellites that also allows the home point to be set, if that makes sense.
This happens in any mode, even ATTI where GPS is not used.
So my question is, what happens if a person is in a location such as a metal warehouse where GPS may not ever be available? Just cannot fly at all? |
