fansa84fe8a4
Probably video lag if that screenshot is off your display screen and not the microSD.
Try setting your channel manually to a strong one (Green bar?) instead of automatic and lower the video transfer as low as it will go in GO 4.
If you are using an Android device, that might be a good part of it too as some of their processors are not as fast, and behind the scenes apps running on them too, as say an Apple iPad Air 2 or the better iPad Pro 9.7" version. I have a couple of Samsungs and they were really a waste of money to run GO 4 with breaking up the video and sometimes shutting down and needing a re-boot - or not connecting at all for a while until the USB picks them up maybe 10 minutes later. Seems like they want to use the RC as a charger more than a data feed at times so they don't connect to GO well.
Good luck running it down.
