Will iPad mini dit in controller?
1865 9 2017-5-30
fanse61be91e
Flight distance : 23255 ft
Denmark
will the controller dit an iPad mini like the mavic controller?
2017-5-30
mtnlandpix
It would appear the size specs are identical on the Mavic and Spark controllers regarding phones or pads that will fit.  Although an iPad Mini will only fit vertically, not horizontally if I read the the width correctly.  (160 mm)
2017-5-31
Jimmers
Flight distance : 49623 ft
There are 3rd party adapters that fit into the Mavic RC so that you can connect a tablet to the remote.  I would assume the same adapters would fit into the Spark RC.
2017-5-31
mtnlandpix
Jimmers Posted at 2017-5-31 08:38
You are correct.  In fact I have one on order from Amazon to use on my Spark whenever it gets here.
2017-5-31
fanse61be91e
Denmark
mtnlandpix Posted at 2017-5-31 09:53
could you add a link to that?
2017-6-1
mtnlandpix
Here is the link for the tablet holder:
https://www.amazon.com/gp/aw/d/B071RK5FYY/ref=mp_s_a_1_2?ie=UTF8&qid=1496364020&sr=8-2-spons&pi=AC_SX236_SY340_FMwebp_QL65&keywords=mavic+pro+accessories&psc=1
2017-6-1
Paraflux
YES, the iPad Mini will fit! Here's a video that shows you:
2017-6-17
bikemerchant
I tried it.  The remote creaks and pops more than I'm comfortable with while putting the iPad mini in.  I feel like the plastic will fail after a few times.
2017-6-17
bikemerchant
Correction, I "stretched" the arms first before I put the Mini it.  Worked fine.
2017-6-18
Bradders
Flight distance : 862283 ft
Upfortuantly an iPad doesn't fit into the controller as well as it does with the Mavic, but this is a very good solution http://amzn.to/2sGaKte
2017-6-18
