[SOLVED] My Mavic no longer has 4K as an option...
1976 6 2017-6-8
Drone_Hack
Just did the lastest update and i can't see the option for 4K footage. The old firmware had the option for 4K 30FPS or 4K 24FPS and both have since disappeared.
Anyone have any ideas or ran into this issue before.
Cheers
2017-6-8
trica de
Flight distance : 1062090 ft
lastest update is x800?
2017-6-8
hungdang
Flight distance : 4931706 ft
Go to HD, change the video transmitting to your device to Normal then you can have 4k for camera
2017-6-8
Oglo
Flight distance : 181693 ft
Just went through the same.
You have to recheck every single setting. It doesn't keep any of your original. Absolutely everything including STICK MODE.
CHECK YOU ARE ON NTSC. NOT PAL.
2017-6-8
Drone_Hack
Thanks HungDang you had it!
2017-6-8
Drone_Hack
All sorted - cheers!
2017-6-8
fans00396000
hungdang Posted at 2017-6-8 21:23
Thank You!!! It worked!
2017-6-9
