RicardoGray
Flight distance : 4356421 ft
Aussiephantom1 Posted at 2017-6-12 16:59
I don't have a solution to your problem, I too am suffering from firmware upgrade issues, I have not been able to fly my P3A since the firmware upgrade. I keep getting the Signal Lost notification even in my own backyard, never had this issue before, I tried downgrading firmware and get cannot downgrade firmware. I have a very expensive paperweight.
I have seen where the phantom gets upgrade but the RC fails or the other way around. Both need to be on the correct version for things to work properly. The latest for the P3A is 1.10.9 firmware package, but the RC version must say 1.8 for things to be correct. The versions will not be the same for both the phantom and the RC, but again they must be on the same versions out of the package.
Try putting the firmware bin file only (not the downloaded folder) in the root of a freshly formatted sd-card. Turn on phantom only and make sure it upgrades and finishes. It will take 20-minutes or so. You need to see a green light on the camera and it will beep D-DD. Now your aircraft should be good. The RC you will update through your Wifi if it is not the correct version. Make sure you have a good internet connection. If successful, turn everything off and reboot. Connect your app via tablet or phone and look in the "About" section to confirm you are on the correct versions I listed above. You may also need to re-link the two together again to make sure things are good. I hope this might help. Although you are in another country, you should not be having these signal or short distance issues in my opinion. |
