Hard landing, gimbal came off. Minor damage, can I repair it?
2414 8 2015-3-13
dugweb.gmail
Short story even shorter, the Inspire came down for a harder than ideal landing. Got knocked around, broke a couple blades, and the rubber dampers weren't able to hold onto the camera and it popped off. Not a huge deal.
Initial inspection I didn't think anything was wrong. Went to plug the camera back into the inspire's little black ribbon cables only to find that they had broken the casing off that they clip into. I was able to slip the casing back on over the pins and the camera worked fine, but as soon as those come loose the gimbal starts going crazy.
It would be a dead-simple repair if I could purchase a replacement piece, but I can't find it anywhere. It seems like overkill to send it in to get it repaired, and doesn't seem like a warranty breaking fix so I wanted to fix it myself.
I attached some pictures to give an idea of what I need to do.
Anyone have experience with this?
Inside look of where the casing broke off.
2015-3-13
misticsea
Flight distance : 87228484 ft
Only one way to find out hook it back up.
2015-3-13
dugweb.gmail
I'm mostly looking for ideas on how to reattach. Soldering it seems like it wouldn't hold well as there's not much for it to grab onto. Super glue seems like it would work, but maybe the vibrations will break it off again.
Ah well, I'll try superglueing it.
2015-3-13
w1der
Sweden
There is rubber inforced super glue that might work for the vibrations ...
2015-3-13
bolwerk.arnold
Flight distance : 12238 ft
You can buy this plate an replace it.
2015-3-13
xzces
Flight distance : 81526 ft
Suriname
If it was originally soldered on, I would solder it. Otherwise some epoxy should do the trick, much better than superglue. It forms a body around the object so would give it little chance to move. Just don't forget to keep pressure on it while it hardens. Once it's cured you can't go back. Good luck!
2015-3-13
dugweb.gmail
bolwerk.arnold Posted at 2015-3-14 03:42
Do you have a link to where I can buy it? I would probably do that, but haven't had any luck finding somewhere to buy it.
2015-3-13
bolwerk.arnold
Search for gimbal plate, perhaps you're  lucky to get them in your country.
2015-3-13
Goodwill
I had this problem as well when my inspire crashed after hiting some branches. The plastic broke off the ribbon, if I didn't have a broken Carbon fibre arm as well I wouldn't have sent it in for repair.
2015-3-13
