New X5 update is out!
1735 16 2015-11-24
gybo102
Flight distance : 2426230 ft
http://www.dji.com/product/zenmuse-x5s/info#downloads
Check it out and discus!
2015-11-24
iSkyUnmannedSys
Flight distance : 7152087 ft
lol http://forum.dji.com/thread-35930-1-1.html
2015-11-24
Machoman
Flight distance : 1036959 ft
Austria
Its a major camera upgrade and no ESC change it should be a good update. And if there should still be something odd you can rollback BUT KEEP the camera upgrade.
2015-11-24
nilsblix
Flight distance : 23047543 ft
Installed just good - now out to try it
2015-11-24
gybo102
iSkyUnmannedSys Posted at 2015-11-24 19:47
why "lol"?
This is for talking about the camera. Info about the lenses and such. Findings about what we get out of the update for the X5.
2015-11-24
iSkyUnmannedSys
Jut saying there's already a thread about it, like from several hours ago :p
2015-11-24
emulsiondown
yummy - new lenses available.
2015-11-24
DJI-Patrick
Glad you guys noticed ! Hope that upgrade satisfy you !
2015-11-24
ezfly
Flight distance : 2885043 ft
Slovenia
i have try update and it say camera needs upgrade (camera requires upgrade) inspire 1
2015-11-25
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
Is there a new sound on the updating process on the Inspire 1 Pro?
2015-11-25
DJI-Dave
This update will be a good one.
2015-11-25
dv613
I just opened the zip file and sent it to my sd card. Inserted into X5 and started rc and Inspire Pro. Camera did not move and has been beeping for at least 15 minutes if not longer. Is this normal? Also on my rc it says "aircraft moving" even though it is on my kitchen counter perfectly level. Should this update take this long or did I do something wrong. Just as I finished writing this, a new message appeared, gimbal gyroscope error yet it is STILL beeping. Was I supposed to unzip files? prior I just copied the folder to the sd card and inserted in Inspire.
2015-11-30
kirk.pleasant
dv613 Posted at 2015-12-1 03:06
I just opened the zip file and sent it to my sd card. Inserted into X5 and started rc and Inspire Pr ...
I am having the same issue .. been 20 minutes and have had 4 inspire 1 startup sounds also go off... stilll getting the dreaded beep,beep,beep,beep.....beep,beep,beep,beep.... not getting a good feeling about this!
2015-12-1
kirk.pleasant
kirk.pleasant Posted at 2015-12-1 20:10
I am having the same issue .. been 20 minutes and have had 4 inspire 1 startup sounds also go off. ...
Another 5 minutes and it was a success!
I had total faith in DJI's upgrade process...NOT!
2015-12-1
gybo102
not supposed to have the RC on while doing updates to the inspire.
2015-12-1
christian
Sweden
Cover the new " Landing Gear Riser " legs the antenna? I think the Radio Channel Quality is poor after upgraded to X5 . Anyone have the same problem ?
2015-12-2
gybo102
Honestly, only have flown 2 times since the x5 has been installed... and even so, I do not  go all that far from me anymore. not worth the risk. But if I notice a difference, I will update this.
2015-12-2
