Phantom 4 Firmware Release Note (v1.1.301)
12345678Next >
34956 296 2016-4-7
DJI-Paladin
Flight distance : 2408 ft
Overview
1.      All-in-One firmware version updated to: v1.1.301
2.      DJI GO app Android version updated to: v2.7.2
What’s New
1.      Improved encryption to enhance security during transmission.
2.      Optimized take-off logic for the aircraft when the compass experiences interference.
3.      Corrected system status information for some batteries.
4.      Increased downloading speed for photos and videos.
Note:
l  Firmware updates for both the aircraft and remote controller is required.
l  If you intend to upgrade the firmware through the DJI GO app, be sure to first update the Android version of DJI GO to v2.7.2 before upgrading the firmware for the aircraft and the remote controller.
Updating Tutorial :
2016-4-7
ahoj
Flight distance : 462690 ft
Sweden
No fix for the gimbal issues (Failing calibration and tilted horizon)?
2016-4-7
Exib
Flight distance : 153760 ft
Seems a strange firmware update does not seem to fix that much at all
2016-4-7
mark.mwilliams7
Flight distance : 1235738 ft
Anyone done the update yet on the P4 ?
Do iOS users get an app update ?
2016-4-7
aidovicius.b
Lithuania
Don't update!!! , after update display signal lost, and you can't take off
2016-4-7
ahoj
Sweden
aidovicius.b Posted at 2016-4-7 13:33
Did you update the RC too?
2016-4-7
Mike_S
Flight distance : 121404 ft
I had the same issue - just been out to fly and it warned me to upgrade, I upgraded my RC and then connected my P4 and upgraded, when I took it back out, no image and could not take off.
However, I noticed it was still telling me to upgrade the RC, so I selected upgrade again, this time it was instant (suspect it just needed a refresh). Rebooted the RC and the P4 and all good.
2016-4-7
Info
Malta
same here signal lost, and you can't take off, yes remote updated too. downgraded to previous firmware.
2016-4-7
mark.mwilliams7
Mike_S Posted at 2016-4-7 13:03
I had the same issue - just been out to fly and it warned me to upgrade, I upgraded my RC and then c ...
You on iOS or android ?
Glad it worked for you
2016-4-7
microcyb
Flight distance : 1095955 ft
I know where you aquired that animation....http://forum.dji.com/thread-47522-1-1.html
2016-4-7
Mike_S
mark.mwilliams7 Posted at 2016-4-7 13:16
I'm on iOS - the issue for me was that even though I upgraded the RC, for some reason it didn't pick it up first time, going though the RC upgrade process a second time fixed it for me.
2016-4-7
BadgerDog
Sorry guys, I'm kind of new to this...
I have an iPad and it still says Go App v2.7.1, so I assume I'm only able to update the firmware to "All-in-One firmware version updated to: v1.1.301"
Regards,
Doug
2016-4-7
mark.mwilliams7
Mike_S Posted at 2016-4-7 13:32
I'm on iOS - the issue for me was that even though I upgraded the RC, for some reason it didn't pi ...
Thanks mike I'm on iOS too I will update later when I'm home
2016-4-7
mark.mwilliams7
BadgerDog Posted at 2016-4-7 13:34
I have an iPad and it still says Go App v2.7.1, so I assume  ...
Yes Doug you're correct P4 only at the moment I would think the app will come later
2016-4-7
projeffrey11
Updated I'm excited to try the latest update.
2016-4-7
CaptRuss
Paladin, you indicate above that the 1.8.80 update is an "all-in-one" firmware update.  Does that mean that it also contains existing battery updates, and therefore also updates any batteries that may have been purchased in the last day or so (which may contain the old v1.4 firmware)?
What is the best practice when updating the GoApp?  Is it best to first uninstall the existing 2.7.1 app, or can the new 2.7.2 app simply be installed "over / on top of" 2.7.1?  When updating the GoApp, does anything need to be synced or backed up first?  I only just received my P3P last week, so I have not flown it yet because I am finishing acquainting myself with it and performing all the necessary firmware updates.  Thus, I am not sure if there really is anything to backup lol
Thanks much-  Russ
2016-4-7
connorschulte
Flight distance : 261033 ft
So I assume iOS users have to wait for the app update?
2016-4-7
DJI-Ken
Flight distance : 1515312 ft
aidovicius.b Posted at 2016-4-7 19:33
If you experience a RC signal lost, delete and reinstall the app and you will be fine.
2016-4-7
CaptRuss
DJI-Ken Posted at 2016-4-7 09:57
"... delete and reinstall the app and you will be fine."
When uninstalling the GoApp, is it recommended to manually remove all remnants too... such as any [DJI & GoApp] directories that may have been left behind after the uninstall?  If I do remove those straggler directories, will I need to take any special steps when reinstalling the GoApp again?
Thanks very much,  Russ
2016-4-7
mgtkilledkenny
Flight distance : 1155823 ft
I'm not getting prompted to update through the GO app on iOS ?
2016-4-7
DJI-Ken
CaptRuss Posted at 2016-4-7 22:37
When uninstalling the GoApp, is it recom ...
Android has a new update to 2.7.2 anyways so just update if on Android.
For IOS just delete the app and all is deleted then reinstall (sync your flight records first.
2016-4-7
DJI-Ken
mgtkilledkenny@ Posted at 2016-4-7 22:38
Go to the Aircraft Status page (app starts on that page) and tap overall status.
2016-4-7
mgtkilledkenny
I have.. And it tell me I have the latest firmware
2016-4-7
mjanzou
Flight distance : 14820 ft
mgtkilledkenny@ Posted at 2016-4-7 07:50
Looks like IOS users will have to wait for their 272 app update
2016-4-7
DJI-Ken
mgtkilledkenny@ Posted at 2016-4-7 22:50
Go to the About page and see if the RC is 1.6.0 and the aircraft 01.01.0301
2016-4-7
aidovicius.b
Lithuania
Problem was solved when i did RC radio update through the android app, because in Apple app, DJI Go program didnt seen the update to 1,8 FW
2016-4-7
aidovicius.b
Lithuania
ahoj Posted at 2016-4-7 14:40
2016-4-7
mgtkilledkenny
All updated, thanks for the advice Ken
2016-4-7
gamette
Flight distance : 2471076 ft
Has anyone successfully updated the firmware with DJI Assistant 1.0.2 on a Mac? Every time I try, I get an "upgrade failed" warning. I tried a couple of different micro USB cables but to no avail. (Running OS X 10.11.4 on a MacBook Pro)
Also, for those using the iOS DJI Go app, do you have to constantly hit "continue" to keep the firmware download going? (I have 50 MB/s internet so I don't think it's my internet speed.)
I think I finally got it working through the Go app, but had to just keep pressing continue to keep the download going.
Just curious if others have had similar experiences.
2016-4-7
slockhart
gamette Posted at 2016-4-7 12:50
Has anyone successfully updated the firmware with DJI Assistant 1.0.2 on a Mac? Every time I try, I  ...
I had issues when trying to use my Mac.  But switched to my Windows machine and the phantom upgraded normally.  But I am still getting a poor signal message on my RC.  I've uninstalled the GO app on my iPhone and re-installed.  BUt I haven't taken it outside just yet.  Will try outside this evening.
2016-4-7
Mad_Angler1
Flight distance : 2741657 ft
FW Update, IOS Process
Turn on Craft and controller and you will be notified of an update is available.
Click on the Firmware Requires Upgrade and it will show you the RC Requires Updating at the top, do nothing at this point
Wait a few more seconds and it will pop up with the craft requires an update as well
Click the craft update and it will tell you to return to the main screen, you will see the following
Click update now and download the update
I found mine keeps pausing on the download, you may need to turn off your craft and controller at this point as Lightbrige may be interfering with your wifi connection preventing the download.
Once downloaded you will need to connect the Tablet to the craft via the USB cable DJI provided, turn on both the craft and controller, after a short time it will allow you to begin the update
Note this update was silent for me with a craft reboot at 96%, the gimbal may twitch as the update proceeds, all normal.
Once complete turn everything off and then turn on just the controller
Now you will get the RC requires update message on its own this time, Click Download Firmware then update.
Once downloaded and updated you should see RC Upgrade Complete, interesting this part of the rc update again was completely silent.
Reboot everything and i got the 'Cannot Take Off' error, it again asked me to update the controller, this time the controller updated again but with the normal update tones we are used to, blue flashing LED as well.
Once complete
Rebooted and everything was up to date and working.
2016-4-7
alpinekiwi
Flight distance : 54803 ft
My issue is that the controller is updated, but when prompted to connect the iPad to the P4, is continues to tell me it's disconnected even when I have made the connection...
2016-4-7
nanu
DJI-Ken Posted at 2016-4-7 14:57
Didn't work for me, still no signal just quick flashing yellow led's, still got a video link?
2016-4-7
DJI-Ken
nanu Posted at 2016-4-8 02:45
Is the indicator light on the RC Green or RedIf Red try to rebind, the P4 is the same process.
2016-4-7
Mad_Angler1
If you have updated the controller before the craft you will need to update the craft via the Assistant 2 it seems.
2016-4-7
DJI-Ken
Mad_Angler1 Posted at 2016-4-8 03:01
If you have updated the controller before the craft you will need to update the craft via the Assist ...
You can also downgrade the RC to 1.5.8 by going to the main page and holding down the Academy section icon (graduation hat) for about 5 seconds then it will take you to a menu that will let you downgrade the RC to 1.5.8 and then start over and update the aircraft first.
2016-4-7
FatedFilmsNC
DJI-Ken Posted at 2016-4-7 10:43
For IOS just delete the ap ...
Android is not indicating that DJI Go has an update available.
edit** I deleted the app and when redownloading it, it was the newest version. Thanks.
2016-4-7
DJI-Ken
FatedFilmsNC Posted at 2016-4-8 03:12
if you go to the Play store you can download the 2.7.2. Could be you don't have automatic updates on.
2016-4-7
FatedFilmsNC
ahoj Posted at 2016-4-7 05:13
I was thinking the same thing, but if you look, that issue was only reported on this forum less than 2 weeks ago. It takes more time than that to program a fix for a new firmware version. maybe next one!
2016-4-7
576DSP
Mad_Angler1 Posted at 2016-4-8 02:23
Turn on Craft and controller and you will be notified of an update is avail ...
Excellent post! Follow all your steps and upgrade worked perfectly! Thanks again
2016-4-7
12345678Next >
