Inspire X5R Transmission problems
1664 2 2016-9-9
tbruegg
Switzerland
on our inspire x5r we have image transmission problems. Occational Images stutter, delays to complete blackouts. The transmission is very weak and often ends after 500 Meters distance, something that never happened on the phantom 3 we had before. Its on both remote and camera remote, used Ipad, Ipad-Mini and Nexus7II. I think it started after installing the latest July Firmware but since we havent flown a lot between May and July im not certain. I tried to re-Pair the remote with the inspire of course updated all firmware but it didnt help much.Anyone else having problems? we probably have to send the drone to dji.
2016-9-9
Mike-the-cat
Flight distance : 22488593 ft
Several of us have posted about this issue. See:
http://forum.dji.com/thread-62472-1-1.html
http://forum.dji.com/thread-62202-1-1.html
DJI has remained silent about this although I'm sure someone is looking into the problem.
The craft I have, I think has some hardware issues on top of whatever is making it more likely to unmask the problem. I have sent it in for repair.  I have another craft that is using the older version of FW without this problem. The problematic craft's problems did not go away with the FW downgrade hence my decision.
My suggestion to you is to down grade to 1.08.01.40 and see if the problem is less severe. If not, talk to DJI.
2016-9-9
tbruegg
Switzerland
Mike-the-cat Posted at 2016-9-9 18:20
http://f ...
thanks, ill will try to downgrade and see.
2016-9-9
