Upgrade issue
917 8 2017-1-8
Ananda4h20
Hi everyone.
Sorry if the thread as already be treated but I just can't find.
I am trying to upgrade my inspire one to the last firmware but there is no way to do it. The aircraft just act like there were no .bin file in the SD... I even try another SD, off course an empty one. But nothing. It is blinking like it is waiting for me to turn the remote control on.  I also tried to do it again with the version  v1.9.1.30 but nothing, same, same.
What can I do?
Thanks for helping me!!!
Ananda
2017-1-8
snath
Flight distance : 5045295 ft
Try formatting the SD card in the Inspire and then add the .bin file and then restart the Inspire and see what happens. One other thing to check is go and see if the Inspire has already been updated in the DJI Go app, hope this helps
2017-1-8
Ananda4h20
I tried to format the SD in the drone but then it is locked. I can't add file into it.
How do we update the inspire in the app ?
2017-1-8
Ananda4h20
snath Posted at 2017-1-8 13:31
Thanks for the answer
2017-1-8
RudeBoyVI
Flight distance : 81191 ft
U.S. Virgin Islands
I had the same issue, trying to update with my x5 Zen. I then tried to do the update with my x3 Zen and all went  well, after the update was completed i updated the X5 and all went well.
2017-1-8
Ananda4h20
RudeBoyVI Posted at 2017-1-8 16:09
Thanks, unfortunately I don't have an X3.... That thing just drive mu crazy....
2017-1-9
Donnie Stugots
Flight distance : 3636782 ft
Read my tips page and see if it helps to find the answer for you .
good luck
donnie
http://forum.dji.com/thread-72851-1-1.html
2017-1-9
501Studios
Flight distance : 171519 ft
Beware!  After updating my Inspire 1 pro, I lost the menu to adjust the camera quality, white balance, video resolution and everything else under that menu.  I have also gained an odd slider between the focus slider and the shutter release on screen.  I am no longer able to adjust the white balance either.
Anyone have any ideas, suggestions or fixes? What is this random slider that I can not make do anything for the life of me, where did the camera settings go?  I can adjust exposure and focus, switch from video to still but that's about it!
2017-1-14
Donnie Stugots
501Studios Posted at 2017-1-14 00:46
Did you update to the latest FW on the  AC using the FW for the Pro ?  You did select the Zenmuse X5 from the product description correct .
Also if you updated to the latest FW on the AC, did you update the AC as well to version 1.7
Please list your current FW to all systems in the  "About" tab of the go app to confirm you have the correct FW insatlled.  make sure you fire up all systems, AC- RC -go app.
If you are sure you have the correct FW, You could sysnc the flight records on the  GO App ( If you wish , I dont care that much bout them )  and then delete and Re -install the go app.
Start here and keep us posted
donnie
2017-1-14
