Mavic Pro serious video problems
7993 29 2017-1-15
Jusba31
Flight distance : 248169 ft
Finland
I'm having problems when filming with my mavic. Sometimes video quality is crappy. Here is one excample video. Filmed in 4k 30fps, auto settings.
Outdoor temperature was about 0 degree celsius and no wind. Was flying in tripod mode.
Here is video file straight out of the drone.
https://dl.dropboxusercontent.com/u/30314110/DJI_0022.MP4
Any idea what's wrong?
2017-1-15
BentonJoyce
Flight distance : 234318 ft
This looks like my drone footage when I had an "abnormal Gimbal Vibration" this happened after I wrecked my drone. If you look underneath where the gimbal is connected there is a tiny metal hook. Make sure your gimbal is attached to that then try again (I would share pictures but my drone is at the service center in CA). Let me know if this helps it could be a damaged gimbal. Also is your app warning you of anything that is abnormal?
2017-1-15
Jusba31
Finland
BentonJoyce Posted at 2017-1-15 10:03
Gimbal is under that hook. App doesn't give any warnings.
2017-1-15
BentonJoyce
Interesting... My footage looked exactly like that when I was getting the warning. It could just be a malfunction in which case you'd be covered under warranty.. I'd have it sent in or maybe someone who works at DJI will see this thread and they might be able to help you. I would also try calabrating the gimbal and do an auto calibration as well that could help.
2017-1-15
Jenee 2
Flight distance : 7852129 ft
I actually cannot see anything wrong with the video. If you think it has a problem then mine must be broken because I cannot get video as good as that.
2017-1-15
Jusba31
Finland
Jenee 2 Posted at 2017-1-15 20:57
Watch it in 4k and full screen.
2017-1-15
Ex Machina
Flight distance : 1806362 ft
Yeah, I see the glitches, first around 8 secs in, a big one around 28 secs in -- hard to notice unless you are full-screen.
2017-1-15
Jusba31
Finland
Ex Machina Posted at 2017-1-15 22:33
Jep, there are many of them. But why?
2017-1-15
CuaC
Flight distance : 369626 ft
I see the glitches too, some jelly effect. Might be the 4k... I think pushing further than 2.7 k in this drone is not such a great idea...
2017-1-16
Ex Machina
I suspect support would recommend resetting the Mavic and reinstalling the firmware. Are you using the original MicroSD card? If not, maybe try recording more video with the originally supplied card to see if that's where the glitches are coming from.
2017-1-16
Jusba31
Finland
Ex Machina Posted at 2017-1-16 08:22
I'm using the SDcard that came with drone.
So you mean downgrading fimware and then update it again?
2017-1-16
Jenee 2
Yes I can see the glitches in full screen. Exactly what mine is doing only a lot worse. Guess I will keep watching to see what the answer is. Mine is doing it on 2.7k.
2017-1-16
Ex Machina
Jusba31 Posted at 2017-1-16 09:36
A factory reset, which is apparently accomplished via the DJI Assistant app, and then a reinstall of the latest firmware seems to be what the support people are recommending for something like this before issuing an RMA and returning your drone for service. Good luck with it.
2017-1-16
Jusba31
Finland
Ex Machina Posted at 2017-1-16 15:35
After reseting everything and made new calibrations. Video looks like this
2017-1-21
Ex Machina
Ok, that's not good. ;(
2017-1-21
Ex Machina
Has the gimbal mount become unseated? Take a look at the first video on this page: http://forum.dji.com/thread-79186-1-1.html
2017-1-21
Gallacherboy
Flight distance : 778209 ft
I also have a very grainy image on 4K @ 30 frames a second. Also when tracking the trees have a jitter effect and it's a clear sunny day so exposure is fine, I even dropped my exposure and it still seems very grainy, I will do further tests and see if the problem continues and will post my findings on the forum
2017-1-21
Jusba31
Finland
Ex Machina Posted at 2017-1-21 16:47
Gimbal looks fine.
That problem is only sometimes. I filmed 10min video and some part of that video looks good and some part has that issue. Can't be any mechanical problem. I have filmed many videos. Some is good and some had that problem. Even in same flight and same settings.
2017-1-21
Ex Machina
Jusba31 Posted at 2017-1-21 23:08
Gimbal looks fine.
Worrisome. Was it windy that day? I noticed a glitch similar to that in your first post in one of my videos and would like to understand what is happening.
2017-1-22
Jusba31
Finland
Ex Machina Posted at 2017-1-22 11:23
There was no wind in those two videos. When I filmed this there was a little bit wind, but not much. That is 1080p/30fps.
Also pictures has the same problem.
2017-1-22
enc3phalon
Try recording a scene at 1080p and see if the jittering persists, If it does not, it could mean the micro SD card is on it's last legs. I had a similar issue with an SD card on my go pro that showed jittering and green artefacts when recording at higher resolutions. It turned out the SD card was at fault and it's write speed was much lower than what it was supposed to be. After swapping out the SD card, everything worked perfectly.  If you have a spare sd card try using that to see if the problem persists.
2017-1-22
Jusba31
Finland
enc3phalon Posted at 2017-1-22 12:48
That last video is 1080p.
2017-1-22
Nick823
Flight distance : 4911 ft
I agree, that video looks good,  Mine are horrible,  I just posted one with suttle grayish lines in the lower middle and up
2017-1-22
airoscar
Flight distance : 272953 ft
I think it's because it's too cold out. I noticed similiar problem but only when it's really cold out like-15C
2017-1-22
Jusba31
Finland
Nick823 Posted at 2017-1-22 17:00
You must be blind Watch it in full screen.
2017-1-22
Jusba31
Finland
airoscar Posted at 2017-1-22 17:43
0 to +3 can't be too cold.
2017-1-22
truemush
Could be an issue with the micro SD card recording rate. The micro SD cards that come with the drone (writes at 20-30 Mbps) DO NOT record fast enough for 4K video. I recommend an micro SD that "writes" faster then the max video bitrate of 65 Mbps. I've experienced friends with similar issues and were fixed by simply changing to a faster write speed micro SD cards. Just make sure the write speed is over 65 Mbps+ since some micro SD cards only show you the read (transfer) speed not the write.
Here's an example you should be looking for if you record in 4K video: SanDisk Extreme Plus
2017-3-23
Griffith
Flight distance : 98537 ft
I agree that at 4K write speed to the memory card could be an issue.
2017-3-24
fanse8215ba9
Flight distance : 344 ft
Norway
I have some glitch-problems too. The glitching is only on the video recorded on the phone, and not on the video on the SD card in the drone. I tried with another phone, and had the same isssue. Anyone that can help?
2017-5-18
OlderDJIPilot
Flight distance : 118 ft
Why have all the videos been removed???
2018-2-19
