Update failure
1324 5 2017-3-26
Keanu
I tried to update my inspire 1 pro but it failed. Now I need the firmware file to reboot it. Could you please send me that file?
2017-3-26
Donnie *
Flight distance : 3636782 ft
What file are you talking about ?  All you need to do is make sure you have the correct Firmware and download it. let me give you a link to the correct file for the  Inspire X5 pro .
Go to the Inspire 1 downloads page , BUT  be SURE TO SELECT THE X5 CAMERA  from the SELECT PRODUCT   then it will open the correct page for downloading.  EXAMPLE BELOW
Most failures now a days are because the downloads page defaults to the X3 camera and you need to be sure you are selecting the Inspire Pro and the X5 camera system.
donnie
2017-3-26
Keanu
Donnie * Posted at 2017-3-26 10:41
Yes I did everything what you said but it doesn´t work. After inserting the sd card, the camera starts blinking red and the drone starts to beep continuous. When I insert the sd card to my computer to read out the failure it say´s:
Packet: WM610_FC550_FW_V01.09.01.30.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
On the internet I was looking for how to reboot the drone and all I found was, that I need a firmware file to do it.
2017-3-27
Donnie *
Keanu Posted at 2017-3-27 00:56
Read my tips page and see if you can find the problem .
There is no reboot file that I am aware of  , (Maybe a long time ago but not anymore .)
Perhaps try loading FW  with another PC  and format  the SD card on the Aircraft .  Also use a PC and Not a MAC, The MAC for some reason can cause problems , I dont know why but they can , Like I say use a PC if you can .  And I own several MACS so I am not being just biased .
I did also confirm that you have the correct file , did you happen to try the latest update rather than the 1.9 ?  go to the 1.10
http://forum.dji.com/thread-72851-1-1.html
donnie
2017-3-27
MedicFL1
Flight distance : 4358570 ft
Make sure the extracted bin file is the only file on the SD card. Delete folders ( they'll be remade automatically).
Give the A/C plenty of time to update.
2017-4-5
Donnie *
Did you have any luck getting this resolved ?
donnie
2017-4-6
