Donnie *
Flight distance : 3636782 ft
Wait a minute , did you update the Aircraft first ? You might get into deep trouble if you did not update the AC first . Which update did you go from to ?
You may get luck and just need to re- link if you updated both the AC and the RC . But if you updated the RC from say version 1.5.70 to say 1.60 and did NOT update the AC first you may get stuck in travel mode and not be able to get out . In that case you would need to rollback to 1.5.70 and then get out of travel mode . Then update the AC first .
Please list what update you did to the RC and what firmware was on the system before . You may need to rollback the Firmware on they RC to the previous one , as long as it was not to big a jump from like 1.3 to 1.7 you should be able to rollback , then re establish communication with the RC and AC and then UPDATE THE AIRCRAFT FIRST , THEN THE RC TRANSMITTER
So give us some more information , let us know if you updated the aircraft FIRST and what version of firmware is currently on the RC transmitter and Aircraft , then we can give you the best advice as to how to get sorted. It may indeed be just a re link that is needed if you did update the AC first and then The RC, sometimes you just loose link , but it could be more complicated ......depends.
Please read my tips page when you have a minute also , it will help in the future and only take about 5 -10 min tops. Tips for loading NEW firmware to SD card and transmitter
donnnie
